How to care for, clean and store the Radiant
Short answerRegularly wipe the case and the bracelet or strap with a soft, dry microfiber cloth to remove fingerprints, dust, and moisture.
How it works
Avoid any direct contact with chemicals such as perfumes, lotions, or detergents, as they can damage the finish of the case and the material of the strap over time.
