Short answerRoaming is when you use your device outside of your home country. Your network provider can charge you extra for this feature. Always check with your network provider before allowing roaming!
Video from the Kompakt quick start guide
To allow roaming
- Press the Control Center button
- Tap Settings icon
- Tap Network and Internet
- Tap Mobile Network
- Tap the Roaming Toggle switch to stop or allow roaming
