How to change the volume level
Short answerThere are 2 ways to change the main volume level on Kompakt but you can also change the levels for certain functions like the alarm or ringtone too.
To set the main volume though the Control Center:
  2. Swipe the sound volume bar below the Bell icon up or down
To set the main volume using the volume buttons:
  1. Press or hold down the volume up button to raise volume
  2. Press or hold down the volume down button to lower volume
To change the volume for certain functions
  2. Tap Settings icon
  3. Tap Sound
  4. Use the sliders to set the level you want
