  3. Mudita Kompakt FAQ
Mudita Kompakt Technical Specifications
Dimensions: 70mm x 128mm x 12.6mm
Weight: 164g
Display: 4,3" E-ink touchscreen; 800x480 resolution
Processor: Quad-core MediaTek MT6761V/WBA
RAM: 3GB LPDDR3
Storage: 32GB expandable with microSD (up to 2TB)
Battery: 3300 mAh Li-Polymer (up to 6 days standby)
Charging: USB-C (10W max) or wireless (2.5W max)
Audio:
  • ACC speaker
  • 3.5mm headphone jack
Connectivity:
  • GPS
  • Glonass
  • Galileo
Camera: Rear-facing 8MP with dual-color flash (warm and cold light temperature LEDs)
Operating System: MuditaOS K (custom de-Googled AOSP)
SIM Card Configuration:
  • SIM tray layout: 1 SIM card slot + 1 hybrid slot (second SIM or microSD card)
  • SIM card format: nano-SIM (4FF)
  • eSIM: supported (deactivates SIM 2 if used)
Durability:
  • IP54 dust/splash resistance
  • Matte mineral glass screen with 8H hardness
  • PC GF casing (polycarbonate reinforced with glass fiber)
  • Reinforced metal frame
Sensors:
  • Fingerprint reader
  • Accelerometer
  • Barometer
  • Gyroscope
  • Ambient light sensor
  • Proximity sensor
  • Magnetometer
