Kompakt technical specifications
Short answerMudita Kompakt measures 70mm x 128mm x 12.6mm, weighs 164g and has a 4.3" E-ink touchscreen, 3GB RAM, 32GB storage expandable with microSD and a 3300 mAh battery.
General
SpecMudita Kompakt
Dimensions70mm x 128mm x 12.6mm
Weight164g
Display4.3" E-ink touchscreen; 800x480 resolution
ProcessorQuad-core MediaTek MT6761V/WBA
RAM3GB LPDDR3
Storage32GB expandable with microSD (up to 2TB)
Battery3300 mAh Li-Polymer (up to 6 days standby)
ChargingUSB-C (10W max) or wireless (2.5W max)
CameraRear-facing 8MP with dual-color flash (warm and cold light temperature LEDs)
Operating systemMuditaOS K (custom de-Googled AOSP)
Audio
  • ACC speaker
  • 3.5mm headphone jack
Connectivity and location
  • 2G, 3G, 4G LTE
  • Wi-Fi 5 802.11 a/b/g/n/ac, dual-band
  • Bluetooth 5.0
  • NFC
SIM card configuration
  • SIM tray layout: 1 SIM card slot + 1 hybrid slot (second SIM or microSD card)
  • SIM card format: nano-SIM (4FF)
  • eSIM: supported (deactivates SIM 2 if used)
Durability
  • IP54 dust/splash resistance
  • Matte mineral glass screen with 8H hardness
  • PC GF casing (polycarbonate reinforced with glass fiber)
  • Reinforced metal frame
Sensors
  • Fingerprint reader
  • Accelerometer
  • Barometer
  • Gyroscope
  • Ambient light sensor
  • Proximity sensor
  • Magnetometer
