Element care and maintenance tips
Short answerWith proper care, the Mudita Element Automatic watch can last for generations. Regular maintenance performed by a qualified watchmaker every 2-3 years can maintain accuracy and prolong the lifespan of your watch.
Temperature
Do not expose the watch to rapid temperature changes or extreme temperatures over 60°C (140°F) or below 0°C (32°F).
Magnetic fields
Do not expose the watch to strong magnetic fields generated, for example, by speakers, cell phones, computers, refrigerators or other electrical appliances.
Shocks
Avoid thermal or mechanical shocks - they may cause damage to the watch.
Harmful products
Do not expose to reactive or corrosive chemicals and gases as this may cause discoloration of the watch case, crown, or watch straps. The watch may also corrode, which can affect its water resistance.
Cleaning
Clean the watch regularly (except for the leather strap) using a soft cloth and lukewarm soapy water. If your watch comes into contact with salt water, gently rinse with fresh water and leave it until completely dry.
Watch strap care
Our vegan straps are water-resistant to splashes which may happen when the watch is worn everyday. However, we do not recommend wearing the watch while showering, bathing or swimming. Clean the strap with a clean wet cloth without detergents in cold water. The straps are not machine washable. When the time has come to replace your straps, recycle metal parts and dispose of the straps in a mixed-waste bin. We recommend replacing your strap every six months for hygienic reasons.
General safety tips
  • Be particularly careful when engaged in work or exercises, to avoid injury to yourself or others.
  • Be particularly careful when wearing your watch while holding a small child, to avoid injury.
  • Do not wear your watch in locations where you watch may become excessively hot, since there is a risk of burns.
  • Be careful when putting on and taking off your watch, since there is a risk of damaging your fingernails.
  • Take off your watch before going to bed.
