Does the Element Automatic emit radiation?
Short answerNo. The Element Automatic is fully mechanical, with no battery or electronics, so it gives off no EMF.
No. The Mudita Element Automatic is a mechanical automatic watch with no battery and no electronics, so it gives off no electromagnetic fields (EMF) at all.
How it runs without a battery
Inside is a Swiss Sellita SW300-1 self-winding movement. As you move your wrist, a rotor turns and winds the mainspring. A fully wound watch runs for up to 56 hours. If it stops, wind it by hand with the crown or wear it for a few minutes.
Magnets affect the watch, not the other way round
The watch emits nothing, but strong magnetic fields can make a mechanical movement less accurate. Keep it away from speakers, phones, computers, fridges and other electrical appliances when you can.
More on care: Element Automatic user guide and warranty.
