Does the Mudita Bell 2 Tick or Make Any Other Sound?
Print
Modified on: Fri, 21 Jul, 2023 at 3:29 PM
The Mudita Bell 2 is designed to be as quiet as possible so that it doesn't cause a disturbance in the bedroom. However, it's not not completely silent, since it still has an analog, mechanical design.
Quiet Flowing Mechanism
The Bell 2 doesn't tick like most conventional clocks, but it does still have a mechanism with spinning cogs, which produces a very slight, constant sound. In normal conditions, this sound shouldn't be noticeable to the user. It's possible to hear when listening closely.
Louder than Usual?
If your Mudita Bell 2 has an unusually loud mechanism that disturbs you at night or if it's making any irregular sounds (other than what's described above), it might be a faulty unit. In this situation, please contact Mudita Customer Support and we’ll help you open a warranty case to have the device repaired or replaced. Click here to open a new support ticket.
Did you find it helpful?
Yes
No
Send feedback Sorry we couldn't be helpful. Help us improve this article with your feedback.
