Set, activate and deactivate the alarm on Harmony 2
Short answerFrom the home screen, twist the main knob to set the alarm time. Deep-press the knob to turn the alarm on or off: the orange band shows it is on. Melody, light and snooze are under Settings, Alarm.
Set the alarm time
On the home screen, twist the main knob on top of the clock to adjust the alarm time.
Turn it on or off
Deep-press the main knob so it changes position. When the orange band is visible, the alarm is on; when it is hidden, the alarm is off. The screen confirms the change, and when the alarm is on, the home screen shows a bell icon with the alarm time.
Snooze and stop
When the alarm rings, light-click or twist the main knob to snooze. Deep-press it to turn the alarm off. Snooze can be switched off, and its length set from 1 to 30 minutes, in the alarm settings.
Melody, light and snooze settings
  1. On the home screen, light-click the main knob to open the menu.
  2. Twist to Settings, light-click, then choose Alarm.
  3. Pick Pre-wake up, Main alarm or Snooze.
  • Main alarm: 17 alarm sounds, volume 1 to 10, and whether the screen lights up and how brightly.
  • Pre-wake up: a chime and a frontlight that start 5, 10 or 15 minutes before the alarm, or off.
  • Snooze: on or off, 1 to 30 minutes, plus an optional snooze chime every 1 to 5 minutes.
For first-generation Harmony owners
Deep-press the main knob on top of your Harmony to turn the alarm on or off. The orange strip shows when the alarm is on, and the home screen shows a bell icon and the alarm time. When the alarm rings, light-click or twist the knob to snooze, or deep-press it to turn the alarm off.
