Mudita Center 1.0.0 and 1.1.0
Updated 8 Nov 2026
Short answerAdds writing and sending messages, Pure backup and restore, and Harmony onboarding and updates. Fixes 33 bugs.
In this release, we have improved the functionality of the Messages application by adding options to create a message, send a message, and the ability to view the sender of a message.
We have also added the ability to backup and restore Pure Phone. In addition, we added an onboarding process for Harmony, also the possibility to check the latest updates and the option to update Harmony via Mudita Center. Moreover, we improved the Overview section for Pure. We fixed 33 bugs in our application.
Added
Backup/restore
  • Ability to Pure’s backup
  • Ability to Pure’s restore
Messages
  • Preview of message author
  • Possibility to create a message
  • Possibility to send a message
  • Messages refresh
Harmony
  • Onboarding process.
  • Option to check information about newest MuditaOS-H (MuditaOS-Harmony) update
  • Possibility to update MuditaOS-H (MuditaOS-Harmony)
Overview
  • Preview to Pure Serial Number and SAR info
  • Preview to Pure’s color when device is connected
Contacts
  • Functionality to preview contacts to be imported sorted by last name
Security
  • Information on how long the user should wait with another attempt to enter the password, after an incorrect entry
  • Option to contact with support
Changed/Improved
  • Changes in legal documents (License, Terms of Service, Privacy Policy)
  • Update Backup/Restore EP documentation
Fixed
Contacts
  • Fixed issue with the contact name not being displayed on the message page
  • Fixed issue with the ability to create a contact without a phone number
Messages
  • Fixed issue with the message not displaying in the message section when it is empty
  • Fixed problem of not being able to access the Message Options menu
  • Fixed issue with messages that continued to appear in Mudita Center after deletion on Pure
UI/UX
  • Design fixes
  • Fixed images on the Onboarding screen
Factory reset
  • Fixed problem with factory reset not working
Help
  • Fixed the functioning of the Help section in the application
Tech
  • Fixed bugs on the technical side of the application
