Mudita Harmony 1.6.0
Short answerLets you choose from 7 clock faces and set a meditation start delay. Fixes 32 bugs.
In this release, we added the possibility to choose the type of Clock Faces from 7 options.
Furthermore, we fixed 32 bugs in our system.
Added
Home screen
  • Possibility to choose Clock Face from 7 options (3 for 24h format, 5 for 12h format)
Meditation
  • Possibility to set a Meditation Timer start delay
UI/UX
  • UI update (Home Screen settings)
Translations
  • Completed missing translations
Fixed
Settings
  • Fixed problem with confirmation of language change action
  • Fixed problem with mixed translations appearing after language change
Meditation
  • Missing texts completed
General
  • Fixed issue with the device restarting when trying to turn it off
  • Fixed incorrect unwanted shutdown of device in transport mode
  • Fixed problem with duplicated action after pressing the back and lightclick button
  • Fixed problem with blank screen when approving certain settings
Home screen
  • Fixed problem with Home Screen flashing during startup
Relaxation
  • Fixed problem with relaxation sounds turning off after alarm or bed time deactivation
