MuditaOS is our proprietary system developed specifically for the Mudita Pure and only supports the Pure.
MuditaOS on Other E Ink Devices?
While it may be possible to run MuditaOS on a different E Ink device, that would require a lot of adjustments to the code. It isn't possible to install our system as it is on any other device but the Mudita Pure.
Should a user try to implement such changes to adapt MuditaOS to another device, all changes done to the software need to be released and documented under the GPL v3 license.
