What USB connection does Pure use?
Short answerLike most modern devices, the Mudita Pure is equipped with a USB-C port.
Universal connection
The Pure comes with a USB-C to USB-A cable. This universal cord would also work with most modern mobile devices and other similar cables could also be compatible with the Pure, depending on their quality (we recommend avoiding low-quality cables). The USB-C end goes into the phone's port and the USB-A end is plugged into a computer or power adapter.
Worth knowing
  • The Pure does not come with a USB power adapter, only the cable is included
  • Visual representation of the included USB cable's ends:
