Short answerThe Mudita Pure's E Ink display has a frontlight that can be turned on or off in the phone's settings.
Users can also adjust its brightness.
E Ink display
The screen imitates the look of paper and provides good visibility even in direct sunlight (as long as the phone isn't held at an angle that reflects the sunlight directly at the user's eyes). Using the frontlight allows users to achieve good visibility at night as well.
